Trailering my baby
RE: Trailering my baby
ORIGINAL: IBEW505
No ties downs,no wheel chock just the lock & load. No problems . I cant see using $100 worth of straps to tie down $20,000 + bagger that I waited so long for. I think you are taking a BIG chance with straps .
ORIGINAL: IBEW505
Headed to Datona myself . Trailering two bikes 1 SG , 1RK on 7x12 . I use www.lockandloadusa.com .Coast is higher than straps but alot easer for one rider to load and unload. Alot safer for myStreet Glide and buddies Road King both 07s .
ORIGINAL: RoadKing06
The trailer is open and has a wind barrier to protect the front of the bikes. It has tied down area everywhere. I only use ratchet straps rated at 1500lbs each (probably overkill) Thanks for the replies. I will be making a few local runs to other Florida events before Sturgis, I'll try the suggestions there.
I've never trailered my bike,I bought my trailer to use as a garage for warm months,instead of using a cover all the time,my trailer doesnt even have tie down points,guess i might want to think about adding some ,at some point,just in cease i have the need to use the trailer,any recomdations on which system works well and is versitle enough to use the trailer for hauling other things as well
ORIGINAL: BirchwhiteHD
HDJIM1158
02-07-2016 10:16 PM
Rich67
15
12-07-2013 05:32 PM
