Street Glide Tri bar light to Road Glide
RE: Street Glide Tri bar light to Road Glide
Pappy....I'm thinkin a black tri-bar wouldn't look too bad on that orange bike. It might fit right on with the black accents on the erst of teh bike....just a thought...
ORIGINAL: SoCal_Pappy
LooKs AWESOME on a RG - Just can't get the sucker in ORANGE...
You can do the mod on a Road King and several HDFers have done it. If you have a RK Custom, your fender is the same as the Road Glide and it's an easy install.
If your RK is a Classic or Standard, there are holes in the lower portion of the rear fender that show when the chrome trim or fender tip lamp is removed and the SG facia is installed--so you either fill the holes and re-paint the fender or find a RG or RK Custom or SG fender color-matched or paint to match.
ORIGINAL: mvinc01
Sweet! Thanks guys. I think I'm gonna still go with the run/brake light.
ORIGINAL: IceHeritage
I Used the Run/Brake Light on my Bike and I love it
ORIGINAL: mvinc01
The connector for plugging the LED into the tail light assembly (after removing the lens) is 73153-96BK. I don't have handy the PN for the sockets that attach to the end of the wires and plug into the tail light assembly. Send a PM to PapaTravis and he'll have the PN as I posted it on his project. I'll see if I can find his thread--not sure if it will turn up, so PM to him will probably get you the info faster.
Also, the sockets require special crimping--if you have an HD Service Manual, look at the Appendix and it will show what's involved. I bought a Philmore WS26 crimper for 8.00 USD at Fry's Electroics that worked well; or, have a HD tech do it for you.
