Does anyone here have the pin configuration for the accessory plug under the left side cover? I thought it was just +12vdc and ground but there are more than two pins.
If you are riding a 08, that is for diagnostic use. look for the one in front of the battery. it is the acc. plug. If you hane two plugs in the left side cover , the other one is for the abs. thats what hd told me. Good luck. Bob
