Header Ping
Old 01-24-2006 | 04:03 PM
00ultra's Avatar
00ultra
Default Header Ping
I just installed a True Dual Headpipe kit from www.fullsac.com and rode about 120 miles. I noticed that when accelerating (mostly in 5th gear at about 80 mph) I'm hearing some sort of pinging. It seems to be coming from the rear cyl. like a header ping.
Has anyone experienced this problem before? I'm running Supertrapps by Kerker. Could they be causing too much back pressure on the rear cyl. ?
Old 01-24-2006 | 05:54 PM
Harley Rulz's Avatar
Harley Rulz
Default RE: Header Ping
My Rineharts did that when they were new but it stopped after a few hundred miles.The dealer told me it was common.
Old 01-24-2006 | 08:33 PM
Retired_Ted's Avatar
Retired_Ted
I read somewhere that the air temperature sender for the ECM is located in the intake manifold - as the TC88 heats up (air is drawn into the throttle body after passing over the cooling fins), ECM leans the mixture and pinging is very likely to occur. So, if we run our TC88's hard (hard acceleration), pinging will be a fact of life unless the spark map is changed. Your dealer is right - of course, and, when we modify the exhaust and intake systems, HD is off the hook if damage occurs.
Old 01-25-2006 | 11:16 AM
00ultra's Avatar
00ultra
I'll run it again to see if it clears up. I can't rationalize it clearing up....if it does'nt I'll change the slip-ons bact to the Harley Touring mufflers an see what happens. Otherwise I may have to get the ECU remapped. Or possibly go with a PowerCommander to enrich the rear cyl. Any opinions between the PowerCommander and SERT ????
Old 01-25-2006 | 11:36 AM
CHEYENNE's Avatar
CHEYENNE
Some like the SERT some like the PCIII.. Alot depends on how much you wanna spend it seems with people.
Old 01-25-2006 | 12:38 PM
lil_gmac2's Avatar
lil_gmac2
They both will work a hell of a lot better than the HD download. Just get that baby dyno'd tuned
Old 01-25-2006 | 12:45 PM
00ultra's Avatar
00ultra
Will do ............. Think I will go withe the PwrCmdr. Then Dyno'd to get correct mapping for my setup. Just don't know if I'm going to leave the Supertrapps on or go with the Harley Touring Muffs.
shrekmoose
05-11-2019 05:31 AM
rchays57
The Dyno Room
09-17-2017 12:57 AM
reesestewww
04-20-2012 06:57 PM
toolbox
10-02-2008 09:45 PM
chriscalabro
Exhaust System Topics
06-20-2007 08:17 PM
Quick Reply: Header Ping
