Need help with a broken bolt
So, bought a nice little chrome trim piece yesterday figuring I could slap it on in 2 minutes. Took a look at the instructions and used the "cleaner" screw to clean the hole threads before install. As I was screwing in the cleaning screw, the head of it snapped right off. I wasn't using much torque at all. Now I have a broken screw sticking out of the hole and can't get it out. This $30.00 trim piece is going to end up costing me a fortune if I can't figure out an easy way to remove this screw. I guess it may have to do with these screws coming from China. Any ideas on how to get the damn thing out before I lose my freakin' mind?
RE: Need help with a broken bolt
Can you get at it with a drill bit? Might want to go to the hardware store and get a left hand drill bit. If the broken off screw isnt too tight in the hole it may back out that way. If not you can use a screw extractor to turn it out then. May have to center punch the broken screw to center the drill bit so you dont drill off center and bung up the threads in the hole.
If the remainder of the screw/bolt that is sticking out is workable, try to file it flat and then use a center punch to make a detente or starter hole for a drill bit. Now you can drill a hole in the shaft of the bolt and use a easy-out. Or if you think you can do it with a small chisel, you can cut a groove in it and use a flat blade screwdriver, or just continue to tap it out with a hammer and chisel.
Also if its sticking out enough, and its not too tight, and you think you can get a set of Vice Grips on it with a good bite, you may get it out like that.
Or you could use a small drill bit like I said above, and then just keep going bigger and bigger on the bit size until it comes out.
You never said what the part your installing was or where the bolt is located. If you could snap a good close up pic of it I may have a better idea. The point is dont rush it.....its a common problem, and can be fixed without too much fuss.....dont get all freaked out about it.
You have 2 options that I can see.
1. If there is enough of the bolt sticking out, you might be able to grab it with a pair of wire snips by clamping and turning and repeaing.
2. You need to use an Easy Out which in layman terms looks like a tapered left handed twist drill. You drill a small pilot hole into the end of the broken bolt. Insert the Easy Out tool giving it a slight tap to seat it into the hole and basically unscrew the bolt.
[IMG]local://upfiles/4575/88D6032926EA499FA4D40C53A211E31A.jpg[/IMG]
It's a Fork Bracket Cover http://www.harley-davidson.com/gma/gma_product.jsp?PRODUCT%3C%3Eprd_id=84552444223806 3&FOLDER
%3C%3Efolder_id=2534374309227509&ASSORTMENT%3C %3East_id=2534374309227509&bmUID=120346719
7487&bmLocale=en_UShopefully this link will work. The screw broke on the left side and I don't have a lift so it's a little tough to get at. I think I'll try the easy out but I was afraid of screwing up the threads. I'll buya good set of vise grips and try that first before I use the easy out. Any other tips before I "screw" this up?
if you can get your hands on a set of stud removers i would try them first ,then the vise grips and if that didn't work and you have access to a welder then i would get a nut to fit over the stud and tack weld it then back it out with a socket hopes this helps.
