HID Dual Bulb Headlamp
#31
I have the DDM Tuning 35W Hi/Lo kit $40. You can see it here: http://www.ddmtuning.com/Product-Cat...-Kits-Lighting.
Very easy to install. I used the free passing lamps hot (+12v), which is on the headlamp wirring harness. You just need a good ground and you are done...
Very bright.
Frankly, If I were to do it again, I would get just the low beam ($25)... It has one less small control box. I never use the Hi beam. But, either way, you cannot go wrong.
Very bright.
