Ness Big Sucker Installation Question
Hi Everyone,
I recently purchased a PCIII and Stage 1 Ness Big Sucker from Fuelmoto. My question is. What bolts do I put loctite on? In the instructions it makes no mention of putting loctite on the Banjo Bolts. I notice that they have a blue coating on the threads. Is this instead of loctite? Also any words of wisdom would be greatly appreciated.
Happy riding,
Willie
Happy riding,
Willie
RE: Ness Big Sucker Installation Question
The blue on the threads is pre applied loctite. I still put a little more on them. Make sure to clean the oil out of the threads on the heads. Loctite + oil = no holding power. Also put loctite on the studs holding the backing plate on but not the bolts holding the air filter. If you loctite the A/C bolts they will pull the studs out when you try to service the filter.
