Just Did The Radio Shack Siren Install
#31
#32
RE: Just Did The Radio Shack Siren Install
ORIGINAL: ROLLNTIGER
Thanks, that would be me. It helps that our oldest son is a manager for RS so I get to go in there and experiment. I just don't understand why Harley sell/installs the alarm without an audible alarm.
ORIGINAL: Drifting Texas
The one in the DYI mod section. I gotta give two thumbs up to whoever originally came up with that idea. It works like a champ!
#33
I pulled the right and the left side covers off my 2006 EGC and I cant see where the main wiring harness is. There is nothing behind the right side and yes I took off the ecm and the part behind it. On the left side there is the cruse control and a fuse box. Sorry I need pictures....
Trucky911
Trucky911
#34
#35
ORIGINAL: TexasVet
For $6 you can't beat this mod and thinking of putting another speaker on the other side of the bike.
#36
ORIGINAL: Badfinger
The first sign of movement the systemgives you a warning, the lights flash and the siren gives a short yelp. If you keep messing around it goes off and stays on for a while. My forks were unlocked so without the fob I turned the switch to ignition. The radio and lights came on and I thought well crap it doesn't work so I turned the run switchon and I heard the fuel pump start up.Again, I thought it doesn't workand someone could be stealing mybike and I hit the start button.
ALL HELL BROKE LOOSE [sm=yikesomg.gif]I almost wet my pants running for the fob...the I don't know how long because I shut it off. It works!
Ride well,
Jim
Ride well,
Jim
#39
Did my '02 RKC yesterday. Take off the rightbag and side cover. Remove the two allen head bolts holding on the control module. Under that, there is a plastic cover held on by two nuts. Remove the nuts, pull away the plasticcoverand hooked to the cover is a three-wire harness with a weather-pac connector cover on it (has ablack, brown, and green wires in it).That is the connector you are looking for. Hook the wires from the siren as stated above. Done.
#40
ORIGINAL: frontiercat
