I'm impressed....should I be? Dyno!!!
Old 02-24-2008 | 11:35 AM
geargrinder's Avatar
geargrinder
Default RE: Yikes!!! Corrected #'s Dyno!!!
ORIGINAL: jcbpa
Well, I am pretty foolish, but it did spark some good conversation: I read the #'s wrong:
Here are the corrected #'s
prior to tune: max power = 55. 42 after tune: max power = 68.14
prior to tune: max torque =65.98 after tune: max torque = 76.54
they said they were having a tough time because it was pretty cold outside? but the chart reads: RO Run conditions: 48.9 degrees F, 29.90 in-Hg. Humidity 8% SAE:0.95.... Now does that make it better or worse???
I don't think anyone came back to answer your question. The SAE correction does not make it better or worse, itmakes it the same. Another words, if you were to re-dyno on this dyno on a daywith different atmospheric conditions, the HP/TQ #s should come out the same.Having a dyno with SAE correction is one of many reasons that the Harley numbed,lieingbutt dyno has long ago beenobsoleted.
It is a good idea to have your bike tuned when the atmospheric conditions arenot at their extremes. Even though today'sengine management systemsare supposed to compensate for such changes, after a few mods, the accuracy of such compensation can get corrupted.
Skippy97
2014-2023 Touring Models
28
06-03-2015 07:36 PM
JVILLEFATBOY
07-05-2010 03:11 PM
dragonx
03-03-2009 05:29 AM
mhud
01-27-2008 08:41 PM
cjackson
03-22-2007 09:25 PM
Quick Reply: I'm impressed....should I be? Dyno!!!
