Upset or not!
Old 02-23-2008 | 03:31 PM
turtleman57's Avatar
turtleman57
Default RE: Upset or not!
Me too, heading to Cherokee NC tomorrow, hope I'm not stranded in the woods and eaten by a bear, lol. Thanks to all for your input.
Lance
  #32
Old 04-29-2008 | 08:09 PM
Pric8779's Avatar
Pric8779
ORIGINAL: onephsyco1
Absolutly ! A weak spark ,or intermittent spark, Just like it was
said A couple of time earlier . Even A plug wire not connected all the way
can cause the light to come on ! Hope the light stays out .
Jack
ORIGINAL: turtleman57
Ok here is the shops answer to my check engine light being on and throwing false codes. At the 15,000 mile check-up had platinum plugs installed. Was told that these had less resistance and was causing the check engine light to come on. Showing a no compression code. How does this sound to all the brain here in this fine forum, and believe me I trust you a lot more than I trust the dealer.
OK, My 05 Ultra started this CEL crap on Sat so I parked it to think about it before my typical freak out when things like this happen.Today (Mon)I take it out and the light comes on under medium to heavy throttle but goes ofwhen I let off or coast. So I come home after work and got on this thread. Went out and checked the plug wireslike several here have mentioned and guess what, rear wire waspart way off; I would say about 1/8-1/4 inch. It ran strong, did not miss, but gave me some back fire on deceleration it didn't used to. Thanks to those withcalm, logical suggestions, you were dead on.Put the wire back where it belongs and all is good.
I'm riding to work tomorrow
  #33
Old 04-30-2008 | 02:44 AM
Comfortably Numb's Avatar
Comfortably Numb
you really should add it as your signature, that would save you some time.
+1 ....only fix the spelling and punctuation first so we can get a 1/2 as*ed idea what it says.
CN
  #34
Old 04-30-2008 | 05:35 PM
LarryInEastTn's Avatar
LarryInEastTn
ORIGINAL: philb252
Yes, I had the exact same thing- I checked over the engine and found that the rear spark plug wire was not snapped into place- the wire boot was over the plug but it wasn't snapped all the way home- no codes since
Ditto, on my bike, & a couple of friends bikes. A common problem with careless techs, and vibration. Too bad the dealer couldn't/wouldn't take time to do the job right.
  #35
Old 04-30-2008 | 08:07 PM
themensh's Avatar
themensh
Ask the mechanic "If this is a false code and don't worry.....how do you know when to worry?"
(kind of like a "small heart attack...don't worry" ?)
Chuck
  #36
Old 04-30-2008 | 08:14 PM
tjmac49's Avatar
tjmac49
turtleman57: +1 Upset. Sounds like the service dept is too busy to address your problem. Harley Customer Service might be my next phone call.
  #37
Old 04-30-2008 | 09:47 PM
IO_Dozer's Avatar
IO_Dozer
Do you by any chance have a PCIII on the bike? I was having the same problem, however my dealer took the time to explain (and prove) to me that it was a result of my bike having a PCIII installed.
thamer williams
01-17-2018 07:13 PM
pamie324
06-03-2016 07:59 PM
Bogie_71
03-13-2016 08:27 AM
streetglide clyde
2014-2023 Touring Models
03-29-2014 09:11 PM
08bluepearl
08-06-2009 12:20 PM
Quick Reply: Upset or not!
