looking for turn signal connector part#
I am putting streetglide front turn signals on my standard. i have the ends already on the new wires, but i need the connector. i found the correct one on NAMZ custom motorcycle productssite (NA-174922-2) but i can not find a f**king retailer anywhere. I also tried looking up Tyco/AMP part numbers through mouser and digi-key with no luck. If anyone can tell me the OEM part number that would be great.
RE: looking for turn signal connector part#
I still had the instructions that came with mine. I think you need the end #2 / housing, socket, 6 position
Part # 73156-96BK
All your wires plug into that one socket and it plugs directly into your old plug on the bike. You will not need #3 The ends on your signal wires are probably #3 if there are two seperate plugs then they are the wrong ones. All the wires go in one plug for the standard. I did the same on my bike, it was a standard.
Part # 73156-96BK
Grewe02 (09-08-2018)
Mine wasn't?? I knew I used one plug soI went back and read the instructions again.
2005 and prior used the 6 position connector and connects up by the left speaker.
2006and later used (2) 4 position connectors towards the bottom on each side of the fairing..
Part # 73156-96BK
Part # 73156-96BK
Just a FYI …. many instruction sheets are available on the Harley Davidson Service Information Portal
https://serviceinfo.harley-davidson.com/sip/index
Here's the one shown in the previous post. They can be printed.
https://serviceinfo.harley-davidson....ument%2F217313
June Bug
03-08-2009 03:06 PM
