I am getting ready to change the oils for the first time. My question is where do you get the O-Rings and gaskets you are supose to inspect or replace if damaged? Are the O-Rings a standard size I can pick up at an auto store? We don`t have a Harley dealer in Tuscaloosa.Where is a good place to order filters on-line?
The o-rings are part #11105 The derby o-ring will last through many oil changes. The plug o-rings usually get torn because they are installed dry. Inspect them if they arent torn, clean them ( and the plug) then put a little bit of oil on the ring before installing.
The same exact thing i do and have not had an issue yet..
