Apes on an 08 w/ABS, info...
"People are putting the W0515 (10" Chubby apes) on there 08's w/abs with no mods." That was a quote from http://www.hdbikeparts.com/or wild1hd when I asked him about putting apes on my 08. I am just wondering if anyone has put 8.5 or 10" apes on their 08 with ABS, and did they have any cable length issues? The only one I see an issue with would be the brake and I don't want to order them and find out the brake line is to tight or just too short. I'm sure this guy knows his stuff, but just wanted someone elses opinion.
RE: Apes on an 08 w/ABS, info...
I was told that there was not exension option for the ABS hose. It is a single piece and there is not a MOCO option for extending that piece.
My dealer was going to work on an aftermarket set of pullbacks to see if the stock ABS hose would work. Haven't heard yet if it will work.
Haven't tore mine down to check, but looking at the parts book I just bought, it appears the brake line from the lever goes to the ABS unit located under the right side panel and then a seperate line goes from the ABS unit to the T-block under the steering head and then into the two lines to the calipers.
Several people on here have done the mod.
