IDS Bearing failure
Old 04-13-2008 | 08:06 PM
relli's Avatar
relli
Default RE: IDS Bearing failure
i dont know what name id call it by but when you've reinstalled it the associated parts that go up against will hold it in place with no play . its more a sleeve than anything and should have no movement once installed. AGAIN thats my belief. ive seen this kinda movement on axle bearing /hub bearing assemblies ive worked on and all went away once everything was tightened down.
  #92
Old 04-13-2008 | 08:08 PM
twilliams's Avatar
twilliams
ORIGINAL: relli
Yes this statement is true, when its all assembled there will be no play.....I am just a little spooked from the talk of bearing failure and wanted to make sure I did not have a grenade on my hands.
  #93
Old 04-13-2008 | 08:33 PM
campincowboy's Avatar
campincowboy
[blockquote]quote:
ORIGINAL: relli
[/blockquote]
I happen to have my 07 apart that I installed ids on (replacing wheels and tires). I installed mine about 8000 miles ago, and it has the same slack, but this will tighten up when installed. My bearing is still good. Don't think you need to worry about the play. Simply hold the two races together and you can see there is no slack. I too have seen this many times in automotive applications.
  #94
Old 04-14-2008 | 10:49 PM
choochoo's Avatar
choochoo
First it is a damn bandaid to a problem HD refuses to correct properly.
Second it is a proprietary unit. This guarantees money for HD as you can only
buy it from them!!!
If you remove it and have subsequent tranny noises ...etc.
Buy a different brand six speed and actually correct the condition.
If it is 08 and under warranty let HD fix it.
  #95
Old 09-27-2010 | 09:15 PM
FLHX_Dave's Avatar
FLHX_Dave
Stage I
I have 50,000k on a 2008 FLHX. I have burned up 5, yes five, IDS bearings. About one every 10,000k. Nobody knows WTF is going on with this bearing. All I know is it sucks.
  #96
Old 09-28-2010 | 08:24 AM
navyman's Avatar
navyman
I just replaced my original due to failure at 46,000 miles.
  #97
Old 09-28-2010 | 08:35 AM
voodoodrug's Avatar
voodoodrug
20k and looks good
  #98
Old 09-28-2010 | 08:49 AM
brogers's Avatar
brogers
I keep one in stock myself and just change it out every other tire change
streeter
07-06-2012 10:02 AM
dgretz
10-12-2009 09:40 AM
ezlife
03-17-2008 12:09 AM
Mikind7
02-13-2008 05:55 PM
kemiha
09-04-2007 06:35 PM
