headlight modualtor is cool
RE: headlight modualtor is cool
ORIGINAL: TexasRedneck
IMO, the modulator is probably the #1 safety feature you can add to ANY bike. Perfect? No - but it definitely helps.
I turn it off in group rides, unless runnin' lead or sweep - other than that, it's on at all times.
Put one on couple years ago and did the light mod also. Use it most of the time, and when I do I see alot of cagers coming out of side streets do a double take. When on long rides especially the interstate several times I come up behind someone and they catch sight of me in their mirror, start slowing and pull over. The modulator, 2 tone silver fairing and the half hemet, I think they believe they are being pulled over by a leo. I get a kick out of the looks on their faces when I go by.
Mine is a Kisan too. I think it was something like $109 to my door. The modulator plug was a really tight fit against the rubber around the headlight plug so I made couple small cuts in the rubber so it would lay down and allow the modulator to fully connect. I haven't mounted the sensor in the inner yet, just ran it up and zip tied to the brake cable.
ORIGINAL: Badfinger
RonH, which model did you use? I wonder how it would look or work in the passing lights?
Ride well,Jim
Ride well,Jim
