short antennas..do they work?
Old 02-12-2008, 08:23 PM
SteveB FLH's Avatar
SteveB FLH
SteveB FLH is offline
Default RE: short antennas..do they work?
Have a hidden antenna (don't know what kind installed by dealer) and lost weather band and most am stations ...sux.... i'm gonna change it
Old 02-12-2008, 08:27 PM
Scootr's Avatar
Scootr
Scootr is offline
I have a marine antenna mounted in the fairing from West Marine for about $10. Works great even when I get out in the sticks. Really cleaned up the back of the bike.
Old 02-12-2008, 08:28 PM
tom73's Avatar
tom73
tom73 is offline
Bought the shorty whip from Advance but lost a lot of reception. Ended up taking blot cutters to the bottom of the stock one and took 18 inches off of it. Works just as well as before and is much shorter now.
Old 02-12-2008, 08:31 PM
HDChloe's Avatar
HDChloe
HDChloe is offline
I have the hidden antenna under my fairing. The works great. I get the wx band, all FM channels I get in my truck, etc. It was not that expensive if I remember right (I got it installed before takingdelivery).
Old 02-12-2008, 08:34 PM
sewerat's Avatar
sewerat
sewerat is offline
I just got one of those flexible rubber shorty antennas and stuck it p under the fairing above the radio and it works just fine, pulls in the stations that same as it did with the stock whip.
Old 02-12-2008, 08:43 PM
bkpa's Avatar
bkpa
bkpa is offline
What year is your SG?They changed the antenna's on the '08's. On the older ones you could cut the whip down and retighten the set screw, on the new ones you have to screw out the entire mast.
You say yours seems to be spinning. On my '08 it comes unscrewed, but gets caught on the rubber o ring by the stud as you remove it.
chappy's Avatar
chappy
chappy is offline
Me Too, both FM?AM and CB
chappy
ORIGINAL: tjmac49
I have the JM short antennas; they have worked flawlessly.
Old 02-12-2008, 08:47 PM
tpseabird's Avatar
tpseabird
tpseabird is offline
ORIGINAL: tjmac49
Same here. My short antennas from JM work perfectly. I plan to do the hidden fairing mount real soon since I will be setting the tour pak up for quick release/detach.
Old 02-12-2008, 08:48 PM
big_al's Avatar
big_al
big_al is offline
I have done both I cut the stock one to about 10 inches and it worked perfect, the I put a $6.00 dollar short antenna with the spiral on it because it looks better and it works good also, I hated the look of a remote control motorcycle with the long stock antenna..
[IMG]local://upfiles/45508/C1E0346536A441E4B9CA0FF05D349AD7.jpg[/IMG]
Old 02-12-2008, 08:57 PM
scottma978's Avatar
scottma978
scottma978 is offline
I bought the rubber shorty from advance also....lost some reception, but it is ok....gonna try the j&m shorty I think.
Quick Reply: short antennas..do they work?
