2008 Corbin Young Guns
Now THIS is a seat and money well spent. It took all of five minutes to install and adjust the rear bracket. The seat presses down on a spring notch latch and you use a key to remove it which is an ingenious mounting system. The underside of the seat is as clean as the top and the seat pan is of very high quality material.
The seat sits me back and down about one inch. Some people have claimed that this seat is hard, I disagree as this is the most comfortable seat I've ever ridden on. The foam is very high quality as it has a unique spring feel in the back support when you twist and release the throttle. The only issue someone else might have is that the side covers and tank clear coat might need to be re-shot due to where the stock seat scratched the finish. It is visible as this seat is a lot narrower. It's not that bad but I'm having the bike painted in about a month so it's a non-issue for me.
Ignore those POS Rush pipes, that is my third set under warranty, dealer installed the last two times and this set blued Sunday!! I have a set of Bub 7's true duals in the garage that are waiting on me to install sometime this week.
[IMG]local://upfiles/49160/E97192BF6794480182071B17932E8BB9.jpg[/IMG]
[IMG]local://upfiles/49160/C2DFF6A4BCD04C7E92ACAD0B9B13E493.jpg[/IMG]
[IMG]local://upfiles/49160/54F11E7F42CD48C489FBB1D6D7A71DE8.jpg[/IMG]
