need advise on bigcitybaffies
Old 02-11-2008 | 08:14 PM
roadkingchuck's Avatar
roadkingchuck
Default need advise on bigcitybaffies
hey---any of ya'll ever tried any of these bafflies and do the
work as stated, are they worth the monies????
Old 02-11-2008 | 08:23 PM
hogdoc's Avatar
hogdoc
Default RE: need advise on bigcitybaffies
They work but are spendy. We weld an appropriate sized washer to a 5/16" bolt and install it 4"-6" in from the end of the pipe. You can then "tune" it by changing the angle of the washer, but this realy only works if your running on a dyno to see what happens to HP, TQ, and Air/fuel ratio. Took a shovel w/drag pipes that wouldnt even rev at WOT and turned it into a completely different animal.
Old 02-11-2008 | 08:51 PM
skratch's Avatar
skratch
what pipes are you going to be installing them in? i had a set that i used on my vance and hines straight shots (for my sporty) i liked them fine, definitely worked better than the standard baffle that comes with the pipes.
anyway, if your pipes are the same size, you can have mine for $25.00 and i'll pay shipping.
Gbass442
03-31-2018 08:14 PM
krakenmoto
12-27-2016 01:50 PM
ryan9977
08-17-2012 08:02 AM
Jethro
04-24-2009 07:14 PM
Mrkicks
08-27-2006 11:45 PM
Quick Reply: need advise on bigcitybaffies
