Knocking out the Cats on 4" mufflers
Old 02-11-2008, 06:53 PM
gashufferjim's Avatar
gashufferjim
gashufferjim is offline
1st Gear
Default Knocking out the Cats on 4" mufflers
Has anybody done it and if so how is performance and sound.
Thanks, Jim
Old 02-11-2008, 07:28 PM
torq's Avatar
torq
torq is offline
Default RE: Knocking out the Cats on 4" mufflers
if by cats you mean baffles yes i did it. it was loud but obnoxious needless to say they are sitting in the garage now and i have rhinehart S/O's and love them.
Old 02-11-2008, 08:15 PM
max56's Avatar
max56
max56 is offline
Been huffin' gas Jim? We don't need no stinkin' cats. Those are for BMW's.
Old 02-12-2008, 10:00 AM
gashufferjim
1st Gear
I drive a gas tanker for bp/ARCO in Sacto
I want to mount some 103" kit mufflers on my RG but my Harley shop says they don't perform well so I thoght gettig the catalys out might help
Old 02-12-2008, 11:24 AM
Pumba11's Avatar
Pumba11
Pumba11 is offline
Yes, I did this to a pair of '06 CVO pipes.
I was able to pound/bore through the cats (the catsare a soft aluminum type screenmaterial about 1.5" thick) using a 1.5" diametergalvanized pipe (make sure it fits into the muffler inlet and the pipe is not real thick walled). I cutthe pipe at a 90 degree angle toabout 18' long. Thenwith a bench grinder,sharpened the end of the pipe, real sharp. On the other endof the pipe Idrilled two 1/2" holes across from each otherandpushed through, and bolted down, a 12" longbolt to form a "T" handle. Once completed, I put the muffler on the gound with the inlet side facing up. Make sure you use some thick carpet or paddingas a cusion for the outlet end. I inserted the sharp end of the pipe into the inlet (this is where the cat screen is) I used small sledge hammer to pound into the cat material. I periodically sprayed in WD40 to provide lubrication. Every few pounds I use the "T" handle to twist around the pipe so it didn't get lodged into the material. After about 5 minutes or so of pounding and spinning I broke through the material. Since I had been makeing sure the pipe wasn't lodged in the material,I was able to pull out a perfect "plug" of cat material. Once out, there was a perfect, clean 1.75 (approx) hole straight thourgh the cats.
Once done, I was very pleased with the performance and sound of the muffler. It was a little bit louder than before with a nice growl when ramping up. Louder than stock but quieter than V & H or Reinharts.
Old 02-12-2008, 12:08 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
PERFORMANCE WILL SUFFER....
Old 02-12-2008, 12:11 PM
Pumba11's Avatar
Pumba11
Pumba11 is offline
Why is that?
Removing the cat "restriction", and what is left is a fully baffled 4" muffler.
Old 02-12-2008, 12:32 PM
SoCal_Pappy
ORIGINAL: Pumba11
Why is that?
If ya remove the RESTRICTION you changed the flow... Reducing the Back-Pressure to the system... Back-Pressure helps the operations of the valve train.. NOT to say it's a BAD thing - but it will effect the overall performance...
Old 02-12-2008, 03:50 PM
Pumba11's Avatar
Pumba11
Pumba11 is offline
Most aftermarket slip-ons reduce the crazy amount of restrictionthe the stock HD muffler has on our bikes. That is why most people get rid of stock mufflers to improve flow and increase tq and hp. I completely understand what backpressure does and that it is needed.
However, on this particular muffler that had an nicely baffled muffler that provides some back pressure, PLUS a flow choaking cat in each muffler was overkill. Removal of the cat eliminated "some" of the backpressure. It is by no means a drag pipe. It would in my opinion still provide more backpressure than most every V&H, Python, Wild Pig, Reinhart yada yada yada slip on muffler out there.
Just my $0.02
Old 02-12-2008, 04:09 PM
CREEPSHOW's Avatar
CREEPSHOW
CREEPSHOW is offline
ORIGINAL: Pumba11
Just my $0.02
I agree. HD pipes are over restricted from the factory. That's one reason why they are so quite.
I gutted my stockmuffler and then welded pipe straight threw the center, "like a drag pipe". Performance was increased after converting my stock pipe into a 2-1 pipe. One would think the open pipe would only create power on the "top end" much like a drag pipe but, no. I think the difference is when making my header into a 2-1 there was restriction created where the two pipes meet making backpreasure. What I am saying is you never know till you try it....
Quick Reply: Knocking out the Cats on 4" mufflers
