Key FOB
Old 02-09-2008 | 08:55 PM
outlaw0013's Avatar
outlaw0013
Default RE: Key FOB
On the 06 here's how to set the Auto Arm.
1 Turn Ign ON-OFF-ON-OFF-ON
2 Press left turn switch 2 times release Confirmation 2 flashes
3 Press and hold key fob until confirmation is received Confirmation 1 flash turn signals
4 Press and hold key fob until confirmation is received ( No I didn't read this line twice ) Confirmation 2 flashes turn signals
5 Press left turn switch 1 times and release Confirmation 1 flash auto arm disabled 2 flashes auto arm enabled
6 Press and release left turn switch to advance through options
7 Turn ign off
See what good a manual does for you.
Old 02-09-2008 | 09:59 PM
Rodent's Avatar
Rodent
Default RE: Key FOB
Sounds like it is more of a pain in the azz if you have the AUTO ARM set-up. I have enough passwords and security codes to remember. I don't need another one.
It's easier to lock the bike and arm it manually.
Old 02-09-2008 | 11:20 PM
FLHXn's Avatar
FLHXn
Default RE: Key FOB
As soon as the stealer explained how the system worked on my 08 SG, I knew I had to go home and learn how to pick my own code and figure out how to enter it on the fly. It is so easy once you follow the steps in the owners manual. Don't get caught miles from home without your fob and not know how to manually enter it..
P.S. Does anyone with the siren have myproblem??? About every 5th time I get on the bike with the fob in my pocket, the alarm will scream one warning before it disarms and lets me start it.. Maybe a bad fob or something??? OR maybe its the usual answer.. it's normal... Hehe.
Baggers Rule!
Old 02-11-2008 | 05:30 AM
captsam54's Avatar
captsam54
Default RE: Key FOB
ORIGINAL: mariner227
If you have not changed your code on an 07 and up hd. You are leaving your bike unprotected from crooks. My dealer stressed this. All are the same from the factory. Change it to be safer.
[IMG]local://upfiles/15666/DB30CAF513D5417FA7526D686B8CE1D2.jpg[/IMG]
What he said!!! Especially before you go to Daytona Bike week or other Big MC event..!!
Also the push button gas cap lock is a good investment..(I don't need to explain why.)
Old 02-11-2008 | 07:51 AM
questor's Avatar
questor
Default RE: Key FOB
When I accepted delivery of my 07 the service manager went over all the features of the scoot and then required me to change the code. He also stressed that they are all the same from the factory and he felt obligated to ensure each owner change it prior to roll-out.
Old 02-11-2008 | 08:18 AM
Phurion's Avatar
Phurion
Default RE: Key FOB
ORIGINAL: rcastorena
You're not alone. Mine does it every now and then, but not with any frequency I can pin point. Just seems occasionally the security system doesn't realize the fob is near and gives me a couple of warning blasts before finding the fobs signal.
Baggers Rule!
Why yes. Yes they do.
Malleck
10-17-2022 07:51 PM
amsedan43
04-29-2019 01:52 PM
POSE51
01-10-2018 12:12 PM
harley0711
2014-2023 Touring Models
28
06-15-2017 10:12 AM
HarleyUK
01-29-2012 07:49 AM
Quick Reply: Key FOB
