which muffler flows better
I have a 2007 ultra classic, I like the sound of the stock mufflers but I want to go to true duals to take some heat off my wife's right foot. The left and right mufflers are different. Does any one know which side is the better flowing? I will get 2 of that side.
RE: which muffler flows better
???????????? Any pair of mufflers are the same.. IE: you can use one or the other on any side..
(Unless it's 2 into 1)
The only way to rid yourself of the heat problem is to buy a set of True Duals.. (also get more air and there is a sert tune that cools the bike down some..) EX: before. hot to the touch air cleaner.. After sert tune, You can put your hand on it anytime..
ORIGINAL: earlehd
Actually, earlehd is right. The left and right mufflers on an '07 ARE different internally. I've had mine off my '07 RK to drill out the baffle plates. Most of the exhaust does go out the right side as it has a long tube in it and the left side has a blockout baffle plate. I knocked out the baffle plate on the left muffler, and while it wasn't that much louder, I did notice that there was less heat on the right side. Maybe I evened out the exhaust flow somewhat?
