TWO FACE TAPE REMOVAL HELP PLEASE!!!!!
Old 02-06-2008, 09:48 PM
fathertime's Avatar
fathertime
fathertime is offline
Location: CHILLIWACK B.C CANADA: have a u.s shipping adress
Default RE: TWO FACE TAPE REMOVAL HELP PLEASE!!!!!
hhaaarrr!!! been there, done that..had a body shop replace the body side mouldings on my 05 dodge diesel p/u 6 inches too high....gottem off (3 day old black paint) but couldn't use my thumbs for a week!!
  #32
Old 02-06-2008, 11:05 PM
torq's Avatar
torq
torq is offline
i too use the dental floss saw trick as far as the sticky stuff i use 3m adhesive remover works very well and says right on the can that it is safe for automotive paint
  #33
Old 02-07-2008, 09:09 AM
Big Peter's Avatar
Big Peter
Big Peter is offline
ORIGINAL: outlaw0013
WD-40 will help remove it.
WD40 works great !
  #34
Old 02-07-2008, 09:16 AM
dougbk's Avatar
dougbk
dougbk is offline
Goo Gone is citrus based and will not harm your paint. It is also good for removing grease an oil from your clothes and other spots on your bike.
  #35
Old 02-07-2008, 09:35 AM
Woodchuck's Avatar
Woodchuck
Woodchuck is offline
Just a couple of thoughts about removing an emblem from a repainted tourpak.
Are your SURE that the label was removed for the paint job? Most likely it was, but...
How long did the shop allow the paint to cure before reapplying the emblem? If it was put on soon after the paint job, you may have the orange peel affect or worse when you take it off.
I agree with whoever said to first try whatever solvent you're going to use in an inconspicuous spot underneath the pak before using it on the tape residue. I would not use gasoline.
  #36
Old 02-07-2008, 12:05 PM
soon to be's Avatar
soon to be
soon to be is offline
ORIGINAL: eglidetrike1
I use Dental floss insted of fishing line and goof off, works every time.
this is my method of choice!
  #37
Old 02-07-2008, 12:15 PM
hdwd2000's Avatar
hdwd2000
hdwd2000 is offline
heat gun works great
Wisenheimer16
2014-2023 Touring Models
06-07-2019 07:15 PM
Rick Tessandori
06-21-2015 04:50 PM
flyingace
08-27-2012 04:27 PM
OwnerOfHarriet
General Topics/Tech Tips
05-11-2009 09:19 PM
buckwheat
01-06-2009 01:44 PM
Quick Reply: TWO FACE TAPE REMOVAL HELP PLEASE!!!!!
