Best Smoked LED Tail Light For SG?
Old 02-06-2008, 08:11 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
Default RE: Best Smoked LED Tail Light For SG?
ORIGINAL: Jsans
I really like those! Can I ask how much they were?
Taillight was $130 and the LED turn clusters we around $65 for the pair. Both available thru Custom Dynamics.
Old 02-06-2008, 09:25 PM
Hoffy's Avatar
Hoffy
Hoffy is offline
Hey Monstermile, those look good. I wanted to do those blinkers too. Can you tell me if they screwed up your flasher like custom dynamics says it might? There is some box you have to buy extra for the blinkers and wire it in if the new lights mess with the flasher.
Old 02-06-2008, 09:58 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
ORIGINAL: Hoffy
I run the Biketronics Tailbones run/turn/brake module with just the LED's in the rear (for now). I talked to Biketronics and they told me you do not need a load equalizer when running just the rears. I'm not running one and do not get hyperflash. I do have their Smart Equalizer to install when I add front LED's.
Old 02-06-2008, 10:31 PM
Hoffy's Avatar
Hoffy
Hoffy is offline
ORIGINAL: Monstermile
ORIGINAL: Hoffy
Thanks for the reply!I guess I will figure on the same cause I want to do the front and rear. I wonder whatsintaled in installing the load eqaulizerbox? Nevermind, I just looked at the biketronics sight, just plug in equalizer. Looks much better than custom dynamics set up.
Old 02-06-2008, 10:34 PM
FX4's Avatar
FX4
FX4 is offline
ORIGINAL: MassHD
Or you can go the PYO way. I thinks its the same as the Cycle Vision.
It would be really good if PYO actually sold that light.
Old 02-06-2008, 10:39 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
ORIGINAL: Hoffy
Depends on which one you run.
Biketronics Smart Equalizer:
Remove seat. Unplug turn signal wiring harness. Plug in module. Tuck it out of the way. Reinstall seat. 5-10 minutes of your time.
Old 02-06-2008, 10:46 PM
Street Glider's Avatar
Street Glider
Street Glider is offline
Thanks for all the info Monster! Looks like I need:
Radiantz LED, FL Turn Signal LED Retroz
Biketronics Tailbones load equalizer
Street Magic tail light cluster
Sound about right???
Old 02-06-2008, 11:20 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
ORIGINAL: Street Glider
The Biketronics Tailbones is a run/tun/brake module. The Smart Equalizer is a load equalizer. Two different things but they can be run together in parallel.
You need:
1 pair of Radiantz clusters 1157 amber for the front
1 pair of Radiantz clusters 1156 for the rear. Use red if you use the run/turn/brake or turn/brake module. Amber if they are just going to be turns
1 Street Magic LED taillight (no window) in clear or smoke
Looking on the Custom Dynamics site it looks like the Radiantz clusters are now Street Magic - Genesis. I am assuming they are the same thing with a new name. But you may want to call to find out for sure. I know my Radiantz carry a 5 year warranty. And the ones shown on the site have a lifetime warranty. That is a good thing.
Old 02-07-2008, 04:07 PM
quackhead's Avatar
quackhead
quackhead is offline
what is the difference bewteen that run/turn/brake module and the one from the MOCO?
Old 02-07-2008, 04:13 PM
HogFather's Avatar
HogFather
HogFather is offline
I ordered the same as monstermile last week should be here any day now. Love the look. Smoked the front lenses last month. It's a much cleaner look, and with the LED bulbs you'll be seen.
Quick Reply: Best Smoked LED Tail Light For SG?
