True Dual guys I need help !
Old 02-03-2008 | 09:08 AM
hoosierdaddy's Avatar
hoosierdaddy
Default True Dual guys I need help !
I installed a set of V&H true duals with ovals last night , so I went out this morning to reset the fuel pack and cycle the pipes so I could recheck everything for tightness . While I had the bike idleing I noticed the rear head pipe was starting to glow red . Whats the cause and whats the cure ?
Old 02-03-2008 | 09:13 AM
hdslam's Avatar
hdslam
Default RE: True Dual guys I need help !
Too lean, you are heating up the cylinder which is burning the exhuast gases. Very laymans terms.
A wrench should be able to give more detailed explanation.
Old 02-03-2008 | 09:17 AM
sanaga's Avatar
sanaga
custom/dyno tune ur bike bro.....ur rear cylinder is too lean....
Old 02-03-2008 | 09:19 AM
pled55's Avatar
pled55
recheck your settings ;i run a fuel pac it seems to work really good
if not you may have to call their tech line for more info.
Old 02-03-2008 | 09:21 AM
asuperheat's Avatar
asuperheat
Yep its tolean I would get it straight before puting any miles on it.
Old 02-03-2008 | 10:21 AM
sewerat's Avatar
sewerat
LEAN IS MEAN ... and that one's gonna hurt, just add more fuel to it.
Old 02-03-2008 | 10:44 AM
Skivvy9r's Avatar
Skivvy9r
+1 on the too lean.
But you didn't say how long you were idling for. It doesn't take too long for an air cooled motor to overheat at idle.
Old 02-03-2008 | 11:10 AM
hoosierdaddy
I'm going to call V&H tomorrow and listen to what they have to say , if I don't get any satisfaction I'll call Jamie about a PC III . The bike was only running for a couple of minutes in my garage and it was about 60 degrees in their . The sad part this may have been happening for awhile since I've been runing the ovals on stock head pipes with the fuel pack and never thought to check the pipes for this kind of heat .
Old 02-03-2008 | 12:38 PM
bob2002's Avatar
bob2002
I don't know squat about the fuel pac,is it working correctly?
iceman5218
04-30-2012 11:27 PM
robkei
Exhaust System Topics
06-10-2010 01:20 AM
Lowco
05-14-2009 06:29 AM
ickeyeddie
04-21-2008 07:38 PM
Bill918
10-04-2006 12:07 AM
Quick Reply: True Dual guys I need help !
