07 ABS Light
RE: 07 ABS Light
Do the '08 bikes without ABS have the tach with ABS light installed on them? If not, they gave you the wrong tach. If yes, then there MUST be a way to have it disabled. Unless you get an answer here, I'd check with who you bought it from for a solution or possible exchange.
RE: 07 ABS Light
As far as I can see, the 2008 'big book' does not have any combined speedo/tachs for 08 models. Are these nowavailable? Presumably the single tachs with housingswill work on 08s - why would they have an ABS lamp in them? I have a 2008 RKC and the ABS lamp in is the main speedo display.
RE: 07 ABS Light
I had this same issue, was able to get the proper tach from the guy I got mine from. He was not able to get me the older speedo (got a whole 08 set off ebay by mistake)so I had to get it through the dealer on Sale..The computer shows the 07 gauges obsolete, but they were able to get me the speedo, it is now 67516-04C version from 04B. The tach you need is 67522-04A it does not have the ABS light found it available at www.surdyke.com for 153.81 for the tach and the speedo is 160.00 through them. I called them when I was in my search and they were very helpful, I ended up getting mine locally because they matched the price for me. I would give them a call they might be able to help.
Good Luck,
Scott
07 EGC
IDS
Good Luck,
Scott
07 EGC
IDS
RE: 07 ABS Light
OK finally got it fixed at the dealer. All they had to do was put it on the computer and disable the light. WOW what a concept huh. Waited all this time on them to get some info on it and they had it all along and didn't even know it. Gotta luv those techs that work on em
