??? for Experienced Touring Members == What are the Top 5 things you would change on a Stock Ultra?
#51
#52
For me, here's my changes:
Stage 1 (AC, fuel management)
Free-flowing Exhaust
Comfortable seat (Mustang)
Highway pegs
Better shift linkage to replace rattling stock garbage
I'm happy after that. Would also throw in an SE comp, but haven't done that yet so have no idea what the different is other than comments here.
Highway pegs
#53
- Highway pegs
- Corbin DualTour
- Chubby WO575 bars
- 9" Windvest
- Pushbutton fuel door
And if I can have 10...
- Zumo 665
- Bottle holder
- TruckLite/CD LED headlight, passing lamps, turn signals, taillight, etc.
- Luggage rack
- Floorboard extenders
- Corbin DualTour
- Chubby WO575 bars
- 9" Windvest
- Zumo 665
- Bottle holder
- Luggage rack
#54
I have a 2010 103 Ultra Limited and since you asked, if I was the man in charge at HD on the new touring bikes I would have a reverse gear and a center stand as standard equipment. I also would replace that, (eventually breaking out in the middle of nowhere, expensive to replace) skinny *** drive belt with shaft drive. ABS would be standard equipment on ALL bikes.
#55
I have an 07 E.G.C.
I would make LED tail light and turn signals standard. I would also have the red trunk lights standard as well. I like the rider back rest and heated seats. I like the K & N RD air filter kit that eliminated the backplate on the football type stock airfilter housing. My wife loved the Kuryakyn passenger arm rest that has a built in drink holder. I also like and have used more than I originally thought I would the luggage rack mounted on the trunk. The 96 cu. in. gets the job done with decent mileage so I would leave that alone. I would have liked a wider back tire (they went to the new frame and wider tire in 08) and mine is an 07. I don't have cruise control and wish I had it. Thats about it. My 2 cents worth.
#56
#58
1. Floorboard extenders $60 Keeps legs off tank
2. Run/turn/brake module and lenses $60 Safety and looks good
3. ISO grips $70 Comfort can't be beat
4. Lower smoked shield $100 OEM is too damn tall and smoked is just better
5. Chrome covers for the underside of the rear floorboards $30 (ebay) The black underside corrodes fast
6. Shift linkage with rod ends $30 (ebay) OEM is junk and can leave you stranded
7. Push button for fuel door $28 No digging for key
8. Chrome fender skirt $55 OEM corrodes fast and is fuly
9. Chrome timing cover $20 OEM Corrodes and is plain fugly
10. Front axle nut covers. $30 Just have to
I'll stop there, i've cost you enough money for now.
#59
1. Sirius satellite radio instead of XM
2. Better quality hermetically sealed gauges
3. An engine temperature gauge
4. Better quality and hermetically sealed switches and controls
5. The fuel door should open up instead of down
6. Factory installed LED tail-lights and turn signals
7. Adjustable handlebars
8. Run-flat tires
9. Built-in air power for shocks
10 Added right side Jiffy stand
11. Jiffy stand neutral safety switch
8. Run-flat tires
#60
