power commander III
Old 02-03-2008 | 12:36 PM
dcfatboy's Avatar
dcfatboy
Default RE: power commander III
ORIGINAL: crackercap
...okay how do you determine what map you have or can you, also the throttle positions are 3 and 100, is this okay you think. The idle runs about 2000 until warmed up and then it settles in at about 950 to 1000.
Any other quirks I need to know? Many thanks again
There is a notes section below the map. This typically has which map you have (at least for the canned maps).
2000 rpm seems high to me. It could be your 0% throttle setting needs to be set.
Really no quirks, unless something just does not seem/feel right.
Old 02-03-2008 | 02:29 PM
LKHA's Avatar
LKHA
I just got done setting my throttle I used this method
1 started PC111 program
2 made connections with usb
3 turned bike to run but did not start it
4 opened the set throttle tool
5 hit reset
6 opened throttle and held it at full till it leveled out
7. let throttle return to close verified # was at 0%
8 hit ok on LAPTOP
9 rotated throttle and verified the position moved on the screen and control unit ( can't wait to run it )
Numbers after resetting
closed 7616
current 7622
open 29368
Old 02-03-2008 | 04:32 PM
cegusa's Avatar
cegusa
If you are checking the MAP with the 9v battery and it says no MAP is loaded, it is likely a weak 9v battery. The PC sucks the life out of them quickly.
kryingame
05-19-2016 10:19 AM
albngore
01-02-2012 07:44 AM
ironhorseoutlaw3
08-04-2011 02:45 AM
gpp
10-27-2010 03:41 AM
clueless
05-07-2007 12:54 AM
Quick Reply: power commander III
