squeak from engine when turned off?
Hello to all, I tried to search this but came up with nada. Ok here it is ..2003 rk, fuel injected, k&n flow master filter, super trap exahust w/discs and open end caps. When I turn off the bike I hear a squeak/chrip it think is coming from the intake. Sort off like the last stroke ended up in a certain place. It does it pretty much everytime though ..thanks in advance. mike
RE: squeak from engine when turned off?
It may be coming from the intake, but it is very common for the rubber mounts at the rear of your slip-ons to get hard with time and chirp.
It is also one of those things that sounds like it is coming from elsewhere. I may be wrong on your bike , but check it out. for real it could be them.
If it is it's best to just change them they are cheap.
