Braided cable dealers
Old 01-17-2006 | 01:14 PM
Bill918's Avatar
Bill918
Default RE: Braided cable dealers
Should look awesome when done. Make sure you post some pics.
Old 01-17-2006 | 01:49 PM
PLUG's Avatar
PLUG
4th Gear
Do you recomend a rear change as I heard the rear wheel locks to easily on hard breaking.
Old 01-17-2006 | 06:25 PM
CHEYENNE's Avatar
CHEYENNE
You can change your rear, but as you stated it will be prone to lock up quicker so that is something you need to decide if you wanna deal with or not?? I personally wouldn't bother
Old 01-17-2006 | 08:17 PM
redscout's Avatar
redscout
Ok.... Since it was brought up...
I did use a Mighty Vac to bleed the brakes... and bled and bled and bled...
I got them fairly tight, but never rock hard. But I had read on another forum (which I no longer subscribe to) that the newer front brakes on the FLH's tend to not retract all the way and you have to pull the calipers, push the cylinders back in, then re-bleed. Some sort of engineering problem. I did that, and it worked, but only for a little while. Now, the brakes work ok, but to get the fronts pretty hard, I have to pump them a couple of times (as the poster suggested) to get them hard (ok, no gay comments). They'll stop ok, but the lever is mushy until I do this (but they were that way before I switched to braided too, which was why I went to the braided, so I'm not convinced it's due to that, which adds more credibility to the poster). They'll get pretty hard, but only after some pumping. Fortunately, I am aware of this, so I watch for it, and also fortunately, they still stop ok if I don't (although with mushy feeling), but I'm wondering if this isn't a better forum to ask about the "sticking" problem.
Anyone else experience this?
Old 01-18-2006 | 10:28 AM
CHEYENNE's Avatar
CHEYENNE
That doesn't sound right at all. Have you taken it to the dealer to ask them what the deal is? There is no way I would let that go.. Brakes are usually a good thing
Old 01-19-2006 | 12:24 PM
harley0711's Avatar
harley0711
Chicago Harley does charge a small handling fee with each order, but trust me, normally it is small compared to any shipping charges... and if you live in Ill, yes there will be sales tax - call 888-338-6868 and ask for Sue in internet sales - tell her the Ca firefighter sent ya - she will take good care of ya... I have bought a lot from them and save a TON of $$$
Old 01-19-2006 | 12:40 PM
Harley Rulz's Avatar
Harley Rulz
Joe,
I'd check with http://www.mandmcycles.com/homepage.htm They have good prices and no tax.Mark is a great guy and will help any way he can.
Good luck!!
Craig
FurryOne
07-30-2016 07:28 PM
SeniorChief56
04-16-2011 09:08 AM
soon to be
04-15-2011 05:41 PM
Fire4Effect
05-20-2010 10:05 AM
DynaJoeMS
09-25-2008 05:25 PM
Quick Reply: Braided cable dealers
