SG LED Light replacement rear fender
RE: SG LED Light replacement rear fender
I wired my saddlebag spoiler LED's as run/brake/turn signals by splicing into the HD run/brake/trun signal module. On the output side of the module, just splice one of the power wires from the right side LED to the brown wire, a power wire from the left side LED to the violet wire, and the ground wires from each LED to a black ground wire and you're done.
The part number for the HD module is 69462-06A (it's the kit with the bullet lenses, but any of the run/brake/turn signal modules should work).
If you come up with another way to wire the spoiler LED's as run/brake/turn signals, let us know. If the brake light function is objectionable for your application, hope you post a "how to." Personally, I'm glad to have the brake light function, also.
Last point, the color code wiring given is for my '04 EG; don't know what yours would be but HD is very consistent year-to-year on color codes for wiring--but check you bike model to be sure.
