Question on checking primary chain adjustment
Old 01-27-2008 | 05:10 PM
Roadking04's Avatar
Roadking04
Default RE: Question on checking primary chain adjustment
What he said!
Old 01-27-2008 | 05:12 PM
lionsm13's Avatar
lionsm13
Hayden makes a pretty good one.
Old 01-27-2008 | 05:21 PM
PhilM's Avatar
PhilM
The HB125 is one of the best auto-tensioners available.
Old 01-27-2008 | 05:24 PM
dawg's Avatar
dawg
http://www.liot.ca/Primary_Gauge.htm
cycle upright on jack
Old 01-27-2008 | 05:26 PM
Mandog's Avatar
Mandog
Is it me or what? I have adjusted my chain several times with the bike on it's jiffy stand. The inspection window is at least 2-3 above the height of the fluid. Maybe you will get a few drops if the bike was used prior, but on a cold engine your not gonna get any unless you over filled your primary.
Old 01-27-2008 | 05:48 PM
murph3204's Avatar
murph3204
I just adjusted my primary chain yesterday at 9600 miles. The last time it was checked was at 1000 by the stealer and obviously they OVERFILLED IT! What I think happened was they just didn't let it fully drain before they added a new quart. I put a pan under the bike to catch it all but when I was all done I was pouring the old fluid back in to a quart container and I had about a half a quart too much !! The maintenance manual warns "Do not overfill the primary chaincase with lubricant. Overfilling can cause rough clutch engagement, incomplete disengagement, clutch drag and/ or difficulty in finding neutral at engine idle."
Now it operates like it should and everything is as smooth as silk. I put HD Formula + in and used a 2x4 to prop up the jiffy stand and it didn't overflow a drop. Kudos to you Steveh326 for doing your own maintenance. I keep running across things like this on my bike that the stealer should have done right but find out they were sloppy in their process. I decided miles ago to do as much of my own maintenance as I possibly can for this very reason.
heavypic
07-08-2021 03:20 PM
DavidStiebel
11-25-2015 08:57 AM
swipter
06-25-2007 08:28 PM
bikerbehaviorist
06-16-2007 04:44 PM
HDF Tech
07-11-2005 12:05 AM
Quick Reply: Question on checking primary chain adjustment
