Biker Etiquette
Old 01-27-2008 | 08:50 PM
Mr Pou's Avatar
Mr Pou
Default RE: Biker Etiquette
ORIGINAL: Real_Big_Tex
Pick the part of the lane where you are most visible to the cages that have the most chance of hitting you. These would be the ones most likely to change lanes into you or pull out in front of you.
I normally run the left tire track, but adjust as necessary. On a two lane, if I'm behind other cars, and see a left turner ahead waiting to cross traffic, I hug the centerline and let him get a good long look at my headlight, then move to the right side of the lane just before I pass him. Likewise, if there is someone on a side road on the right, I hug the right side of the lane, let them get a good look at the headlight, then move to the left side right before I pass.
1.) Put your headlight in a position to be seen for as long as possible
2.) Movement can help them see, like I do above moving from one side of the lane to the other. Also creates space.
  #52
Old 01-27-2008 | 08:51 PM
btefft's Avatar
btefft
ORIGINAL: Lord Albany
Another post I made in the "Biker wave" thread:
Last weekend I fell in behind a couple bikers who passed me on the highway. I kept a distance behind them but I followed them since they were headed in the same direction. After a while I got the one-finger wave. Ever since then I have been wondering if I was in the wrong to fall in with them (and got what I deserved), or if they were just being ******.
What do you say?
I feel the 1 finger wave was wrong, if you stayed a distance behind them. But if they overtook you, and passed you, maybe they were angry that you speed up to match their speed. I would have maintained my speed and let them get on down the road. Just my 2 cents.
Hack
  #53
Old 01-27-2008 | 08:52 PM
Lord Albany's Avatar
Lord Albany
Farns,
Thanks for the reply. For the record, I did not fall in with the other two bikers, just kept pace with them. I kept what I thought was a respectful distance from them. About 3-4 car lenghts. I wasn't certain about the "rules" so I didn't try to get too close. They were riding hard and I wanted to get me a little. After they sped up beyond my skill level I dropped back.
Thanks for sharing your thoughts. Thanks to you other guys as well.
Ciao,
Albany
  #54
Old 01-27-2008 | 08:54 PM
Mr Pou's Avatar
Mr Pou
ORIGINAL: PapaTravis
Stop on one side of the lane, perferably with an escape route line of site. That way, if you pop the clutch to get out of the way, or do get rolled on by the vehicle behind you, you will not get sandwiched between the two...
As the first cage comes up behind you (5-10 car lengths) start to randomly flashing the rear brake light. Not an even flashing, but some spaz pattern. Helps get their attention.
  #55
Old 01-27-2008 | 09:13 PM
btefft's Avatar
btefft
ORIGINAL: Mr Pou
I do the same when I am braking, like at a red light or stop sign. A few light, randomly-spaced squeezes of the brake lever, hopefully, will get their attention.
  #56
Old 01-27-2008 | 09:21 PM
sharkeydude's Avatar
sharkeydude
Farns,
Ciao,
Albany
If that's the case then, they were dicks. Those are always the ones bitching that nobody stops to help them. Good luck and great ride by the way!
  #57
Old 01-28-2008 | 05:18 PM
farns's Avatar
farns
Farns,
Ciao,
Albany
Sorry, Lord Albany, I was not trying to imply you fell in with them by design.
Personally, 3-4 car lengths is kind of close if your on the highway, but be that as it may, they were wrong to "salute" you if you ask me.
I have experienced similar things, as I am sure most have. If someone "falls in" with my group, there is no finger waving etc, we carry on, but just don't like it.
Enjoy the road!
  #58
Old 01-28-2008 | 07:33 PM
roadglidepa's Avatar
roadglidepa
Take the safety course and you will have all the answers then take the ERC. Then the next time you see him put both feet down.
Dave
  #59
Old 01-28-2008 | 11:18 PM
Lord Albany
Cool, cool. So what do you ride? Where's the pic?
  #60
Old 01-28-2008 | 11:41 PM
GasCan's Avatar
GasCan
Ride to stop means pickthe spot where you want to stop and keep enough forward momentum going until your ready to brake to that spot. Ride in with both brakes applied, and use only your rear brake for the last 10 feet. You will find this delivers much better balance and will avoid locking your front wheel up at slow speed if you hit some marbles or an oil/antifreeze patch.
I always ride to a stop with the rear brake as described above, and when I stop...I always watch the vehicle beind me to ensure they are stoping. Once they are stopped, only then do I shift to neutral to wait for the light, otherwise I keep it in first and i'm ready to drop that clutch if I need to move out of the way quickly. Always watch other vehicles around you, and always check the intersections in both directions before you ride through. I always put both feet down. Simple advice, but could save your life.
Have fun, and ride safe.
Quick Reply: Biker Etiquette
