Brake Light Modulator
RE: Brake Light Modulator
You could connect a Back-Off module in-line, and then you'd have the modulating brake light.
http://www.signaldynamics.com/lighting_control.htm
Check out this link;
http://www.customdynamics.com/signal..._modulator.htm
Check out the comment at the lower right...indicates cruise control won't work with that particular module. I have one and was going to put it on my 08 Ultra until I happened to read this warning about the cruise.
(looks like only the base "back-off" module will cause cruise problems, other modules appear to be ok)
http://signaldynamics.com/products/Modules/wigwag.asp
Put one on my 08 ultra - just have it hooked to the brake light for now. 5 Quick Flashes & Steady On:
The tour pack lights or the center light? I would like mine to go to just the tour Pack lights they are the best as far as eye shot I think!!!
ORIGINAL: norskehd
