08 ultra perf help
RE: 08 ultra perf help
The dealer "installing" the SERT doesn't really install anythingon your bike withthe SERT; it's a computer interface that allows the bike's ECM to be reprogrammed to make a/f and timing adjustments that are needed when changing the airflow into (the hi-flow a/c), or out of (the Rush slip-ons) your engine.
If the dealer "installed" the SERT there should be a dyno chart of the bike's performance after the install/mods to the ECM--ask the dealer for it.
You should see a gain of about 10/10 hp/tq.
Browse around the forum posts from yesterday - apparently HD just came out with the new SERT for the '08s. That may provide some more flexibility. You should definitely see some performance gains with the gear you have installed. Next step could be the Stage 2 103" big bore kit if you're so inclined...
