King tourpack backrest?
RE: King tourpack backrest?
The regular, armchair backrest attaches with sets of two holes in the center and on each side; a regular King TP from HD will come pre-drilled for the regular backrest, so you will have two sets of holes to fill on each side if you use the chopped TP backrest. They can be filled with plastic plugs, and color-matched using HD touch-up paint. Other than reading about guys considering this, I haven't read of anyone actually doing it or seen pics of the install.
Would enjoy seeing the pics if anyone has them.
Don't understand the question, do you mean behind the backrest? If that is the case I used washers and nuts. The chopped TP back rest has it's own bolts and isolators that you will have to drill holes for.
Measure carefully. I made a template out of cardboard and checked/rechecked everything.
ORIGINAL: uweldit
You are so right about measuring carefully. The dealer had a chopped TP, so I made a template by placing a sheet of paper on the TP and rubbing the holes with a pencil. Worked like a charm. Just measured the distance of the holes when placing the template on my TP to make sure it was centered.
I really like the clean look of the chopped pad on the King TP. Makes the SG look sleeker.
ORIGINAL: Harleypingman
The lanyard support needs a retainer for good support, so I used regular metal nuts to self-thread itself onto the plastic retainers. They work fine.
ReidRik_Von
04-25-2012 02:28 PM
