Wheel Bearing Question.
RE: Wheel Bearing Question.
No dude...25mm is the standard bore size of a 6205 or 6305 ball bearing. The bearings with inch dimensions are more costly(at least in the industrial market) and not nearly as common. I know it can cause some pain trying to change from one to another, but in the long run, the metric dimensions are better because they are more common.
ORIGINAL: Rev00
So HD went from a 25.4 mm Bearing down to a 25.0 mm bearing? Why for such a small difference? Just to be different? So they went to a bearing that is 16 thousand of an inch smaller.
Yes, I pretty much knew that, just being a little sacarstic. They honestly should have done that when they went to the 1" to begin with. Metric bearing sizes are always easier to get and were somewhat less expensive.
I started to state what JakeDog did but then I left it alone.
