Whats everyone running for a rear tire?
Old 01-24-2008 | 10:22 AM
Firetender's Avatar
Firetender
Default RE: Whats everyone running for a rear tire?
03bagger, for about $ 35, you can contact http://www.pingelonline.com/rear_sprocket_spacer.htm
and install the wheel spacer between wheel and pulley. This will let you run the 2004-and-upHD DUNLOP 402 tires (up to 142 mm)that will give you a bigger contact patch, longer tire life and more cool factor. The spacer means no clearance or contact issues, no trimming of the belt guard, no wear marks on whitewalls, etc. I've run this for years and am really happy I bought it. It added a feel of stability and runs smoother on the highways.
Old 01-24-2008 | 10:38 AM
molsen's Avatar
molsen
I do not mind Dunlops, support the home town people. Made in WNY btw, kinda cool. However, on my old '98 RK they were elete II on there replacement and they were bad. Stepped up to Avon VenomX 140 rear 130 front and absolutly loved them. Wore verywell.After finding out to usea little more air on the Dunlops than recomened they seem pretty good so far. If not then the lops are gone and Avonare in or Metzlers depends....
Old 01-24-2008 | 11:14 AM
Choke03RKC1's Avatar
Choke03RKC1
Ditto the Venoms.......work well on the roads here....had metzlers before the venoms which also worked well until the rear tire delaminated and went all lumpy on me.....fortunately it didn't blow out.
Nothing really wrong with the dunlops...just experimenting.
Choke
Old 01-24-2008 | 12:00 PM
FastHoss's Avatar
FastHoss
I run the Michelins,only been on for about 2,000 miles,so far so good.2005 stock eg..Dunlops have only gone about 6,000 miles each time for me.I do like the pattern of the Dunlop better though
Old 01-24-2008 | 12:07 PM
Cryptoboy's Avatar
Cryptoboy
Avon's here (18x3.5), even if I was running the stock wheels I'd put on the better tires. Dunlops are a very hard compound, which is great for longevity, but lousy for handling and ride. Avon and Metzler are probably some of the best compromises out there.
Didn't Harley increase the stock tire size to 150 rears starting with the 2003 bikes? (and then increased again with the 07's)
Old 01-24-2008 | 12:22 PM
Peppa1's Avatar
Peppa1
Stock Dunlops. Usually get 12,000 + on the rear so I'm fine with that.
liscio42
Wheels/Tires
09-08-2018 11:34 PM
jory434
12-05-2012 11:01 AM
Hitechluddite
10-14-2012 06:30 AM
2007fxdc
03-22-2008 10:42 AM
jd_underdog
07-11-2006 12:18 AM
Quick Reply: Whats everyone running for a rear tire?
