Streetglide amp: Kudo's to Pez
Getting my 07 Streetglide ready for Bike Week. Been to Biketoberfest several years in a row, never made the big show cause you can't ride there from Ohio at the end of February. Never trailered... till now. Gonna have to but back to the reason for the post:
I had replaced the factory speakers with JM's. The sounded a LOT better, but I was still looking for more. Was checking on Hog Tunes for an amp, it looked like there were setups to convert to 4 speakers, but I don't have a tour pack or plan on adding back speakers.
Shot Hog Tunes an email asking if I can get the Ultrasound, just use the supplied 4ohm speakers and amp. I got an immediate response, instead of just saying yes and cashing my check, he said he would set me up an amp to run withmy existing2 ohm units or send me an amp and new Hog Tunes 4 ohm speakers for a few bucks more, but still less than the Ultrasound setup would have cost. He even made sure I understood the amp would 1. improve bass 2. improve clarity and lastly 3. increase volume, in that order.
I haven't got the gear yet, can't comment on the soundbut that is some da&m fine customer service.
Thanks Pez, well done.
RE: Streetglide amp: Kudo's to Pez
The amp does use the outputs of the HK radio in the bike (factory). It is plug and play, no splicing or dicing.
I hed even told Pez I had J&M speakers when he offered to set the amp up to run them, they are 2 ohm. The amps normally run 4 Ohm Hogtunes speakers. I ordered speakers too, that way it is all one vendors equipment so if a problem arises with either the speakers or the amp there is no fingerpointing.
I read the install instructions on the Hog Tunes web site in PDF, looks really easy.
It is easy - I just installed the amp on mine when I added the speaker kit in the lowers. The only semi difficult part is snaking the wiring harness under the tank. The fuse part is pretty big so I took the fuse out and cut the cap portion off which helped me get it through. Then just zip tied it back together on the other side. Other than that just follow the step by step "unplug this, plug in that" and before you know it you're done.
