Going to 117"
RE: Going to 117"
Holy sheit on a dresser batman! When I read 117" I reflected back on an incidence where a freind of mine was racing a GPZ 1100 on his punched out sportster. 110mph in 3rd gear (or was it 2nd?)when hebanged in the next gearhe sheared the bolts off'n his rear sprocket. While I am no where near you guys mechanical expertise I was wondering as you punch up the motor do you also upgrade tensil strenth of nuts and bolts around the bike, in key locations to accomadate the exra tourque?
RE: Going to 117"
Dave, sounds like you'll soon be riding a MonsterBagger! The only big-inch failures I'm familiar on on the rear sprocket involved a 120" motor shearing the decorative cover off through the bolts - made a real mess! I made a note to never run a bolt-on cover over the sprocket. Have a great riding season on your new mill!
"April 13, 2002...I had fun with my 106 ft-lbs until I learned an important lesson again: cheap chrome won't get you home. Cheap chrome will only sit you on the side of the road..."It" being a driveline ****** that stopped me in the first church parking lot that I had been in two years. The pulley had come loose from the rear wheel, messing up the pulley and stripping the threads in the rear wheel. Yes, I used red Loctite. Yes, I torqued the bolts to specs. What I did notice when I did these things last winter was that the pretty chromepulleycover ($20) dimpled under the required bolt torque. On a "normal" Harley, it would not have allowed the free-play to work the bolts loose and cause the failure. With low-end torque like the FrankenKing, the dimples became tears, which gave the bolts 1/8" of loose threads. Once the threads were loose, it was just a matter of time before "it" happened...Your badassed motors deserve more than a cheap chromepulleycover. If a customer ever asks for a pulley beautification project, tell them chain, BDL pulley, or nothing at all. Show anybody wanting a chromepulleycover this letter so that they may learn from my mistake. Mine will soon again be the bulletproof cycle that I have grown to know and love..."
RE: Going to 117"
Should be great and a lot of fun when done. I originaly tryed the stock intake on my 06 with stock injectors on my 113" I just felt I could get more hp so I orderd the 50mm from h/d with the higher flow injectors 4.89. The dyno estimater on the sert had it at 131 tq and 109 hp. the tq peaked at 4000 and hp at 5000. Thought I could get more hp and keep my tq. with the new intake if not then I will install the higher flow injectors in the stock intake. Just dont think the stock injectors could feed enough fuel to get the hp up. but I think the 25 degrees I have flow even less than earlyer years. But good luck in your build.
RE: Going to 117"
Well I just left my buddys shop and all my parts are back home again in Indiana, assembly will start tomarrowon my bike. Ended up having Darkhorse do the bottom end with a S&S wheels and rods. I should have some pictures to post in a few days my builder said he will also post them on another forum ???? I'm starting to have withdraws. This has been a real loooong winter
RE: Going to 117"
Hang in there Dave, the wait will be worth it. Long winter is right, I have a new engine ready to ride and it will still be many weeks before I can get out, so I can sympathise completely.
You will be impressed when you get your bottom end back from Darkhorse, it will be smooth as butter.
Fat11Lo
Engine Mechanical Topics
41
09-13-2017 12:08 PM
leeinmemphis
Exhaust System Topics
04-09-2009 07:06 AM
