Use of red turn signal lenses on front of bike ?
Old 01-23-2008, 07:51 AM
big_al's Avatar
big_al
big_al is offline
Default RE: Use of red turn signal lenses on front of bike ?
If you put red lenses and you are riding along someone might say,, damn that motorcycle has reverse?
Old 01-23-2008, 08:42 AM
soon to be's Avatar
soon to be
soon to be is offline
Texas Department of Transportation - TRC-547-324
states the following:
(c) Turn signal lamps:
(1) shall be mounted at the same level and spaced as widely apart as practicable on the front and on the rear of the vehicle; and
(2) may be included as a part of another lamp on the vehicle.
(d) A turn signal lamp shall emit:
(1) a white or amber light, or a color between white and amber, if the lamp is mounted on the front of the vehicle; or
(2) a red or amber light, or a color between red and amber, if the lamp is mounted on the rear of the vehicle.
Just as said in prior posts!
Old 01-23-2008, 10:18 AM
rome304's Avatar
rome304
rome304 is offline
you dont need the po po stopping you for that.
Old 01-23-2008, 10:28 AM
rambo1's Avatar
rambo1
rambo1 is offline
red in front? just put tinted covers on those amber bad boys and it'll look goooooooood
Old 01-23-2008, 10:44 AM
OhioSkully's Avatar
OhioSkully
OhioSkully is offline
Put the smoked len's on the front.
I put the red on the back now everything is red looks good but front i have amber right now. May go with the smoked. I ride alot with my dad and he hates the smoked says boy those are dangerous cant see them.
Old 01-23-2008, 12:07 PM
IBHarley's Avatar
IBHarley
IBHarley is offline
my 71 FLH had red lens then again it was an x PD bike
Old 01-23-2008, 01:05 PM
maxum96's Avatar
maxum96
maxum96 is offline
ORIGINAL: kurtlange
illegal in most, if not allareas.
Nice picture from the top of Trailridge road in the Rocky Mountain National Park.
Old 01-23-2008, 02:18 PM
nwbobnw's Avatar
nwbobnw
nwbobnw is offline
Illegal in Texas.
Old 01-23-2008, 02:24 PM
leohd's Avatar
leohd
leohd is offline
IT IS ILLEGAL, I'd go with a smoked lense to play it safe
Old 05-28-2008, 06:56 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
ORIGINAL: tyrant33
Dothey need to be amber on the front to be legal?
From Chapter 43 of the Delaware Motor Vehicle Code:
[blockquote]
ยง 4347(b): "Any motor vehicle may be equipped and when required under this chapter shall be equipped with lamps or mechanical signal devices showing to the front and rear for the purpose of indicating an intention to turn either to the right or left. When lamps are used for such purpose, the lamps showing to the front shall be located on the same level and as widely spaced laterally as practicable and when in use shall display a white or amber light, or any shade of color between white and amber, visible from a distance of not less than 100 feet to the front in normal sunlight..."[/blockquote]
Does that answer your question?
Quick Reply: Use of red turn signal lenses on front of bike ?
