Spotlight Connector Problem - ARRGGHH
Ive searched and couldnt find anything on this so Ill just ask: Im replacing the spotlights on my 07 FLHT with amber sealed beams from J&P. Right size but I understand the connectors are different. On the new sealed beams they are the screw type and I understand on my bike there is some sort of female plug that goes to the present setup. (Im sure somebody has been down this road before.) Is there an easy way to remove that female plugso I can screw the blades on the new sealed beam?Any advice appreciate, Im an idiot at electrical ****. Thanks in advance.
RE: Replacing Spotlights - Connector Issue
Just spent an hour trying to remove the existing connector on the spotlights with no luck. All I did was gouge the plastic connector. I know I can cut the wires and put on crimped on spade connectors but Id like to slide the ones that are already on it out of the existing plastic connector in case I ever want to go back to clear spots. I looked at the drawing in the DIY section and the connector is similar to the top one but I tried depressing that tang lots of times with no luck.Is there a better drawing someplace of that connector and how to remove the wires?Anybody got a pic of the thing with an arrow pointing to what needs to be depressed or whatever to slide that damn thing out? This is why Im not an electrician. ARRGGHH.
