I Got This From The Iron Butt Website...Pretty Good Info
[align=center] Iron Butt Association's
"Archive of Wisdom" (AOW)
1. Know your limits and plan your trip around them. If the longest ride you have ever taken is 300 miles in a day, don't plan a trip with a string of endless five- hundred mile days. Iron Butt Association surveys also warn of an important trend in long distance trip planning (see Chart A). Discounting weather or other problems; after an initial mileage peak on days one and two, daily average mileage will steadily drop during trip days three to seven. On day seven of a trip, the typical long distance rider will comfortably ride about 65% of the average daily mileage that they would book on a two day trip. If the pros have this type of mileage attrition rate, would you plan on any less? Also include large easy-to-cut loops into your trip plan. If you do get behind schedule, this is the easiest way to skip part of your trip without ruining the rest of it. Whether you are capable of riding 300 miles per day, or 1,000, the ability to make miles tends to decrease as the length of the trip increases. The most severe loss is in days 3 through 7, where Iron Butt types then level out to about 65% of their peak capacity.
[hr] 2. Forget about high speeds. Forget what you've been told; high speeds and long-distance riding have little in common. A steady rider can book more miles, enjoy more mountain vistas and ride more twisty miles than a canyon carver bent on making the best times across a mountain pass. Besides the obvious effects on fuel mileage, which means more time wasted looking for gas, and the fatigue caused by fighting the effects of pushing a motorcycle through the wind, riding much beyond the flow of traffic will land you a hefty speeding ticket. While you are on the side of the road having a spirited discussion with a Police officer about your 10/10ths riding style, the turtle-like rider on the Honda 250 will wave as he sets himself up for the next set of corners.
[hr] 3. Leave your drugs and coffee supply at home. It's this simple, drugs and other stimulants do not work! If you need No-Doze or other drugs to stay alert (the Iron Butt Association includes coffee and colas on this hot list), it's time to stop for the day and get some serious rest.
[hr] 4. Prepare your motorcycle before the trip. With vacation time in short supply, why would you waste time during a trip to have your tires replaced? It is often cheaper to replace tires and chains at home rather than squeezing the few remaining miles from them to only find that they are not available. Additionally, quality motorcycle oils can go the distance. It is not unheard of Iron Butt types grinding away 10,000 or more miles between oil changes. Running hours between oil changes and work load means more than miles. A motorcycle ridden around town will need more frequent changes than one used on a long trip.
[hr] 5. Avoid adding accessories or doing maintenance immediately before a trip. If it can be avoided, don't use a trip as a test bed for a new exciting accessory. This is particularly true for electrical system farkles. It's asking for trouble to install new auxiliary lights or perform other mission-critical electrical modifications right before a rally. This leaves no time to thoroughly exercise the system for proper behavior before having to depend on them during a long night ride. And don't forget, even the best mechanic can make a mistake. Try and avoid picking up your motorcycle and heading out directly on a 10,000 mile trip. A trip is also not the best time to try out that new rainsuit, helmet or packing technique!
[hr] 6. Use an electric vest. Even on the warmest summer nights, after a few days of 100+ temperatures, a 75 degree evening ride can send a chill through your body. Add in a cool, wet day and the benefits of an electric vest mean that no
