Tri Bar LED on Ultra
RE: Tri Bar LED on Ultra
Just bought one from Chicago HD for $143.
Have fun installing it.
When you go to install, here are some hints.....Snap in the tribar light into the extension first.Check the alignment of the tabs to the bosses on the extension for the two self tapping screws.Mine was way off and had to slot the tabs so the screws would go in straight.Good idea to drill the holes bigger(maybe another .020")in bosses.Mine cracked.
After you have checked the above ,remove the tribar light and install the exstension(easier to install the lock nuts,washers,and fender brace) then snap in the light.
ORIGINAL: Razerman
First introduced on the Street Glide? Is this the same or all new?
ORIGINAL: Harleypingman
Razer: It uses an LED that is the same size as, and can replace, the SG LED, but is a run/brake light; not justa running light as the SG originally was and continues to be.
