McCuff Gas Filler with Ultra
Old 06-12-2009, 05:02 PM
RoadKingKamchi's Avatar
RoadKingKamchi
RoadKingKamchi is offline
There is a whole lotta hate going on in this one... I think that a little too much gas has been sniffed, and is causing some TUDE to be shared. Probablyshould use the McCuff so that the fumes don't get out of the tank and create this situation again... just my 1 cent (after taxes)....
  #72
Old 06-12-2009, 05:17 PM
gunner11's Avatar
gunner11
gunner11 is offline
Ditto, fill it manually, keep an eye on it, and it shuts off when it's full. If I have an extra millimeter of space at the top, so what? I fill up in less than a minute or two.
  #73
Old 06-12-2009, 08:53 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
Was in Roswell a few weeks ago, filled up, no problem. Same thing in Ruidoso, Cloudcroft, Tularosa, and Alamogordo, no problem filing up. When in El Paso, It is a problem filling up. We have hi-pressure pumps, and I have a problem filling my ultra without spilling/splashing gas gas on the tank. Thats why I use the McCuff here in town. If anyone has a solution to filling up, when You cannot control the fuel pressure, please tell me how. PS, If You have an ultra and coming to El Paso, Stop by and see Me, and we can go to the gas station and You can show Me how to fill your ultra without spilling Gas. If You fill up without getting gas on your tank, I will buy Your gas and a few beers. ThanK You.
  #74
Old 06-12-2009, 09:00 PM
bdude's Avatar
bdude
bdude is offline
Got one and I use it! I Like it and happy to get rid of those click , click look see what I got!! Put it on auto and it fills to the brim in one shot. Everyone has their own option, I just say I like it and think it works good for 20 bucks I think it was worth it.
  #75
Old 06-13-2009, 07:41 PM
rg_dave's Avatar
rg_dave
rg_dave is offline
Decided to try this. I got a deal on the HD version at LSHD when ordering my oil cooler. I haven't had a problem filling my tank when I was paying attention but have had a couple of mishaps with epa pumps. I took someone else's idea and velcroed it to the top of my left bag. It works well. It allows me to fill the tank on one click with the bike standing up. On the jiffy stand it comes a little short. No splashes and no looking down the hole and clicking to keep from overfilling. No gas smell. I can fill my tank with no problems without it but it is convienient. To each their own. Ill keep mine.
  #76
Old 06-13-2009, 09:20 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
Well Gunner11, I'm waiting for a reply/offer!
  #77
Old 06-13-2009, 09:28 PM
dlrshort's Avatar
dlrshort
dlrshort is offline
Default This should help, found this on the internet
How to Fill Motorcycle Gas Tanks
By Josh Crank, eHow Editor
Rate: (0 Ratings)
Motorcycle owners face a constant struggle at the fueling pump. Most commercial gas station pumps are designed with four-wheel auto gas tanks in mind, and the safety shut-off valves are designed accordingly. When you fill up a motorcycle gas tank with one of these, the safety shut-off valve will usually engage when your tank is only partially full. The simplest way around this problem is outlined below.
* Email
* Send to Phone
* Print Article
* Add to Favorites
* Flag Article
* Bookmark and Share
Difficulty: Moderately Easy
Instructions
Step 1
Pull up to a gas pump. Put your motorcycle up on its kickstand. Most motorcycle manufacturers recommend filling up motorcycle fuel tanks with the kickstand up because it puts the tank in the optimal position.
Step 2
Prepay or use a credit card if necessary to activate the pump, then put the nozzle all the way into the fuel door. Pump fuel into the bike until the safety shut-off valve engages and the pumping stops.
Step 3
Pull the nozzle out of the fuel door. Hold the nozzle handle and trigger with one hand, while you use the other hand to push back the rubber sleeve surrounding the nozzle. Pushing back this sleeve should block the shut-off valve from reengaging.
Step 4
Stick the end of the nozzle about 1 inch into the fuel door and resume pumping. You should be able to actually see the fuel level rising by looking through the gaps in the fuel door.
Step 5
Stop pumping when the fuel level nears the top of the tank. Replace the nozzle, and close the fuel door.
All kidding aside I actually bought a McCuff but haven't used it yet.
  #78
Old 07-19-2009, 09:12 AM
mrmatw's Avatar
mrmatw
mrmatw is offline
It works, have attached to the high way bar, out of the way... How much did I use it???? 70% of the time. Those times I used it.. Whew, another biker filled his bike after mine, same pump. The pressure sensor was working to welll apparently, about 2.50 all over the tank! I'll keep mine in use for a little longer.. Each their own, I respect others and their points as well. Ride Safe, Long and have fun! Tom
  #79
Old 07-20-2009, 03:17 AM
HDriven's Avatar
HDriven
HDriven is offline
Lightbulb
i use the mccuff and like it very much
it is easier
  #80
Old 07-20-2009, 05:35 PM
IzzoQuazzo's Avatar
IzzoQuazzo
IzzoQuazzo is offline
Retired Admin
Received 9,041 Likes on 3,711 Posts
I won a McCuff at a rally about 3 months ago. I tried it and it worked ok. I put the pump in the McCuff and just stepped back. It shut off but it wasn't as full as I usually can do myself, so I stopped using it. Then the other day, I ran across my first new nozzle. Didn't give it a second thought. Filled up manually and got a big splash back. I was pissed. In 30 years of riding all kinds of bikes I've never had that happen to me. From now on, I'm going to watch out for the new nozzle and use the McCuff when I see it. Now where did I put that damned thing?
Quick Reply: McCuff Gas Filler with Ultra
