SERT
RE: SERT
1st make sure you understand I am not an expert. The SERT is a performance enhanser. Because it canchange the air to fuel ratios and it can change the timing of the ignition it can make the motor run cooler. I guess it could make it run hoter too depending on how the changes are made. A program disk comes with the little pocket match box size black box (the SERT). The program disk has some factory programs that can be loaded to your bikes computer (the disk is put into a stand alone computer desk top or laptop and via cables connects to the SERT and the SERT connects to the bikes computer via cable). The factory settings can be improvements to your bikes performance and possibly make the motor run cooler.
My advise is to ride your bike long enough to break it in and at the 5000 mile oil change, if you are not satisfied with the performance, heat etc, have the SERT installed and a DYNO tune. If you put different pipes on, I would get a different air filter (like the Screaming eagle air filter) and have all of it installed at one time. Ask for a before and after DYNO so you can actually see the differences.
I know at least one real biker that has had his bike over 18 months and has not made any mod's to it. He likes the MPG and takes pride that his Harley has not cost him any more money for add ons.
RE: SERT
The reason recent-vintage bikes run hot is because the MoCo has to lean them out so much to meet emission regulations. Were it not for those regulations, stock bikes would be delivered from the factory running richer (and hence cooler).
A SERT, or similar devices that allow re-mapping of the EFI, provides the capability to richen the fuel mixture - so you're basically doing what the factory would do were they allowed to.
RE: SERT
ORIGINAL: vettedog72
Did he say 'REAL BIKER"?[:-]
RE: SERT
ORIGINAL: Duracell
[sm=popcorn.gif]
