Jagg oil cooler, can you use a K&N oil filter
RE: Jagg oil cooler, can you use a K&N oil filter
The Jagg 4700 with thermostat and 4600 without thermostat lifts the oil filter 1/2 inch higher than the SE unit.I fitted the 4600 on my motor with the manual thermostat. I had no problems with it unscrewing when I remove the filters.The oil lines run out under the oil filter making servicing easy unlike the SE unit that runs the oil lines over the filter
Received 7,733 Likes
bmaier
03-08-2012 11:39 AM
mi2az
Oil Archive (no new posts)
07-25-2011 06:06 PM
