Engine Misfiring Scare!
Old 01-17-2008 | 06:27 PM
67xlch's Avatar
67xlch
Default Engine Misfiring Scare!
After going to the 95 in., TW37 cam and new bearings ect, I have about 300 miles and did my 3rd oil change to Amsoil recently. I always pull the plugs and turn the engine with the starter to build oil pressure before starting after doing an oil change. I didn't have a chance to ride so I just checked for leaks and let the bike run for a little bit. Several days later i rode to a local watering hole and the motor cycle was missing and sputtering at every rpm that I used. Ran terribly! I thought I must have screwed up the carb when rejetting or that some part of my rebuild had gone south, so upon returning I listened and wondered for a while. No solutions, so I started by removing the plugs and lo and behold, the front plug had no gap. Just what I need, a stretching connecting rod! Well, I regappped the plug and replaced it and the bike ran perfectly. I remembered having dropped it when removing to build up oil pressure. Sure am glad it was that simple.
Old 01-17-2008 | 07:44 PM
vette's Avatar
vette
Default RE: Engine Misfiring Scare!
WHEW
Old 01-17-2008 | 07:48 PM
Dorkman's Avatar
Dorkman
Forgot to gap new plugs on a bike once. Kicked myself silly trying to start that thing...
Old 01-17-2008 | 08:03 PM
crackercap's Avatar
crackercap
sometimes it's the little things that cause much of the grief, glad yours was a quick fix
Old 01-17-2008 | 10:15 PM
pop1's Avatar
pop1
No harm, No foul
astarks82@gmail.com
Engine Mechanical Topics
13
07-26-2017 06:36 AM
Squintsy
General Topics/Tech Tips
04-16-2016 06:00 PM
jpbutler1983
04-20-2015 08:14 AM
pleasants9
04-21-2010 05:42 PM
Hooter1
Exhaust System Topics
04-08-2009 10:53 PM
Quick Reply: Engine Misfiring Scare!
