Reflector removal
RE: Reflector removal
Do it in this sequence heat it up with a hair dyer till it will wigle a little then spray wd-40 on it then double up on some fishing line and use that like a saw then it should fall of or you will be able to just twist it off then just goof off or goo gone to get the rest of the residue off and then repeat it on the other side.
I have always had good luck with just " grip it an rip it"[8D]
then after what i like to do is heat up the left over parts and use a credit card to gently scrape off the rubbery glue stuff, I have done this to lots of reflectors. While your at it you can get rid of the frame ones, the crash bar stickers, the air cleaner stickers and the fork ones if they haven't already disappeared.
