Race Tuner
Race Tuner
I have a friend that installed a TMax on his 07 Road King. He has offered me his ECM and Race Tuner (SERT) if I can make it work on my 07 SG. If I install his ECM and use his race tuner will it work on my SG. I know its locked to the original VIN. But, if I use his ECM how will thetheECMknow it'snot the same bike. If I need it dyno'ed or tuned I will use his VIN while having it done. Can anyone help with question? Thanks.
RE: Race Tuner
old:
IMO, your friends ECM and SERT should work fine on your SG. Same year, same touring family! The ECM will probably require a few miles of variable rpm/speed riding to relearn thedata coming fromyour SG; but I would bet those two components will work just fine. IIRC, all late model touring bikes are now using the same generic, replacementECM that gets an initial map uploaded from the Digital Technician appropriate for the model bike it's being installed on.
Make sure you find out if your friend had a modified SERT map in his RK. If his was simply a Stage 1 with equipment similar to your SG, you should be fine. Otherwise, upload a map to your SG that's applicable to what mods you have done.
The ECM/SERT doesn't have a clue as to what bike/vin its installed on.
Let us know what mods, if any, you have done to your SG; and good luck!
RE: Race Tuner
Do a search and I think you'll find that it will work but the ECM will need to be married to the bike. No Idea how it knows it's been moved but I have read a couple of threads that say it will start up and run initially and shut down within a couple of minutes. The dealer has to do something with the digital technician but the swap will work fine after that.
Good luck.
Good luck.
