Saddlebag Security Solution
Old 01-09-2008, 09:24 PM
Badfinger's Avatar
Badfinger
Badfinger is offline
Default RE: Saddlebag Security Solution
Well Crap! Thanks for the info and a solution!
Ride well,
Jim
Old 01-09-2008, 09:59 PM
MustBBrent's Avatar
MustBBrent
MustBBrent is offline
I did something similar.... but I used a washer and a nut instead of the wingnut. You need a wrench to pull it out. I also used a locking washer to keep it in place. No longer a quick release... but that is what I was trying to get rid of.
Old 01-10-2008, 01:27 AM
PapaTravis's Avatar
PapaTravis
PapaTravis is offline
I read another post about a guy who used a couple of u bolts, drilled a few holes in the bottom of the bag, fastened the u bolts around the bottom rail, with the nuts inside the bag. Just another thought... besides, drain holes for the melted ice is a plus... just sayin'...
Old 01-10-2008, 03:41 PM
rome304's Avatar
rome304
rome304 is offline
looks good.
Old 01-10-2008, 03:54 PM
JTE2518's Avatar
JTE2518
JTE2518 is offline
I've seen where you can drill a small hole in the bolt close to the wing nut and put a small pad lock throughthe bolt..
Old 01-10-2008, 04:02 PM
HogFather's Avatar
HogFather
HogFather is offline
A lot of good ideas here replacing the quick clip. The biggest advantage I see to this mod is it has to be a stronger link and the twist pins. The bike and me this weekend in the garage for a little bag mod. Thanks guys.
Old 01-10-2008, 04:09 PM
captjon37's Avatar
captjon37
captjon37 is offline
I used stainless bolt and locknut. simple
Old 01-10-2008, 05:52 PM
CigarCritic's Avatar
CigarCritic
CigarCritic is offline
Someonecanremove your bag in under two minutes by removing the bracket bolts. Looks like you are going to have to replace those with button Torx's.
Old 01-10-2008, 06:33 PM
ironspirit_3's Avatar
ironspirit_3
ironspirit_3 is offline
Before leaving for Sturgis, I bolted mine in so the nylon lined nut was on the inside of the bag and the rounded allen head was behind the strut. Nottrue theif-proof, but at least it's more time consuming. And the truth be know theives are like bullies, they only want to tackle the easy stuff. It did notget in the way for anything I stuffed in the bag and really brought me piece of mind. I went last time without doing thisand just felt a ton easier this time.
Old 01-10-2008, 09:10 PM
big_al's Avatar
big_al
big_al is offline
thanks for the picts..
Quick Reply: Saddlebag Security Solution
